Hey guys, well Ive finished the plane and the CG is right at 5" so I am good there but the onw thing I have an issue with is that the lateral balance is pretty bad. I moved everything over as far as possible but it still needs about oz on the Right wing tip to be perfectly balanced. Any suggestions. I really hate to add weight [:'(]or cut covering to put in wieght.[:'(] But it will never do good hovering or tracking with it that bad, so I have to do somthing.[
Thank you,
Need all the info possible
