ORIGINAL: dw_crash
Hello Jetjoe Owners,
For those interested, I received the factory defaults for a JJ1400 Fadec. They are:
The JJ-1400 Fadec setting:
Max speed: 160000 RPM
Idle speed: 45000 RPM
Stop speed: 30000 RPM
Max temp: 800 C
Min temp: 100 C
pump start point: auto+2
Start ramp: 4
Acceleration delay: 18
Deceleration delay: 18
Stability delay: 45
Thanks for all the help,
DW_Crash
Hi,
Where did you get those parameters???. I am using the following:
Idle speed: 42000 RPM
Stop speed: 28000 RPM
Max temp: 800 C
Min temp: 100 C
Start ramp: 6
Acceleration delay: 40
Deceleration delay: 30
Stability delay: 50
Equipment:
JJ-1400
Pump Flight Works A-200
Fadec Nades V05
Battery Lipo 7.4Volt 2200 Mah
