Good prop?
Hi.
I have a TF cessna 182 in construction and a OS 120 Surpass III w/pump. What would be a good prop for this combo? I do not have enough ground clearance for a 16 diameter prop and want this plane to fly scale, not to speed. I imagine that this engine is only needed at fuull power for takeoffs, isnīt it?
What idle and top rpms will the engine run with the prop you say?
Thanks.
