Aquacraft .46 Engine
If it doesn't stop when you close the throttle, it sounds like you have an air leak somewhere. This will also show up with inconsistent runs on the engine too. Check to see if the carb is seated good and check the head and backcover bolts for any that are loose. Let us know what you find.
Suptter
