RCU Forums - View Single Post - Compression gauge
Old 01-08-2003 | 11:56 PM
rsieminski
Default Compression gauge
Shouldn't the pressure be relative to the compression ratio? With gasses, if you 1/2 the volume, you double the pressure. I would think that different sized engines with the same CR, would have similar readings?
