RCU Forums - View Single Post - Blade CX Engine Problem.
Old 08-19-2006 | 12:35 AM
j beede
Default RE: Blade CX Engine Problem.
If your throttle was turned up when the blades hit the ground you may have suffered a failed 4-n-1. Take your CX to a hobby shop that has a demostrator CX and see if they will swap 4-n-1 units to see if that is what the problem is. As you probably know, the 4-n-1 is the most expensive part in the CX. []
