RCU Forums - View Single Post - Air Hogs Aero Ace!
Old 08-19-2006 | 08:52 AM
  #2491
Neurotex's Avatar
Neurotex
Default RE: Air Hogs Aero Ace!
ORIGINAL: novielo
i will try with the n20 and defender props. my only concern was that i tought that the 2 n20 at 10-15grams where way to much to make it fly...
I forget the difference in weight between the stock AA motors and the N20's with
props but I believe they only add about 2 to 3 grams more weight. You definately
have to remove the black plastic motor mount casings the Defender uses. They're
just junk weight.
The wing area on the jet is enough to handle the extra weight. If you want it to climb
even more try hollowing out some of the foam on the fuselage. Might be able to get
rid of a gram or two there.
