RCU Forums - View Single Post - CHARGING IGNITION BATTERY???
Old 08-19-2006 | 10:11 AM
Geistware
My Feedback: (16)
Default RE: CHARGING IGNITION BATTERY???
How do you disconnect power from the ignition module when the engine is not in use?
Are you using a switch, disconnecting the battery manually from the ignition or what?
ORIGINAL: shogunmst
I am running a DA 50 w/ignition and I am trying to figure out how can I charge my ignition battery without having to diconnect it from the ignition everytime I need to charge? How are some of you charging your ignition batteries? There has to be wasy to isolate the ignition module without having to umplug the connector to the ignition every time.
Shogunmst
