RCU Forums - View Single Post - OS 46FX Help
Thread: OS 46FX Help
Old 08-20-2006 | 08:55 AM
BSARGE
Default RE: OS 46FX Help
Yeah I have, as I have actually replaced the tank...however this morning I found two things which may be causing my problems...
1: The nipple on the muffler for the pressure line looks like it was put in slightly crooked, so I put some RTV sealer around it, thinking maybe I wasn't getting the back pressue I should.
2: After removing the tank for the 1000th time I noticed I could easily pull the brass tubing out front the tank even though the screw is tightened down...so I figured maybe from opening up the tank a million times it lost it's ability to seal everything tight...so I happened to have an extra dubro tank and used the parts from it and it is now sealed up real tight...
So I am going to try today to fly it again and see if that helps!
-Bill
