RCU Forums - View Single Post - APC Props?
Thread: APC Props?
Old 08-20-2006 | 11:08 AM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: APC Props?
I took a old plastic spinner back plate that was busted. Then took a Dremmel tool with a sanding drum and ground it down to the same size as the thrust washer. This is light strong and works great. Another thing on APC props. The back mounting surface is not flat. Take a "T" bar before you balance it and sand it flat.
David
