RCU Forums - View Single Post - Which exhaust system should I get for the HPI Baja 5b?
Old 08-20-2006 | 11:27 AM
Timmahh
Banned
Default RE: Which exhaust system should I get for the HPI Baja 5b?
the Jet pro is a bit exposed for my flavor... but works very well. just easy to get dented. i seen the Samba pipe mod to get it out the back. looks very nice. and should be pretty usefull. only issue i can see is if you happend to come down arse first, the samba could bet plugged with dirt or it could possibly put a bend/crack in the exhaust manifold if it landed hard enough... Between the 2, i would go with the Samba if it were me, due to the much less exposed pipe of the JetPro.... personally i use the TGN XCan with great results. sure its not a Tuned pipe. but then again its 80.00 but imo just as good for bashing and there is no exposure to worry about.
gl with your choice, any will work gr8, its just the amount of exposed pipe that could be the biggest issue you face.
Timmahh
