RE: Deadstick Problems
Count the turns or seconds it takes to fill your tank. Take out 1/2 of the fuel and tune your engine slightly rich from max RPM. This will ensure you are not going lean due to low fuel. Did you check for leaks in your clunk line when you had the tank out?
