RCU Forums - View Single Post - Balancing the cg?
Old 08-20-2006 | 02:12 PM
RCKen's Avatar
RCKen
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Balancing the cg?
ORIGINAL: elenasgrumpy
ORIGINAL: RCKen
ORIGINAL: Dave trimmer
now i'm confused again
Join the club!!
Ok, let's make sure we're all on the same sheet of music then. You are asking if you should balance your plane with the retracts up or down... correct????
Ken
Lol, I was wondering when one of you big strappers was going to show up![sm=50_50.gif]
Hmmm, is a "big strapper" a good thing or a bad thing?????
I've been semi-lurking the last couple of days. I'm playing "hired gun" in another forum this weekend.
So if I understand the question he wants to know if he should balance with the wheels up or down. I think it was said earlier but from what I understand he has retracts that have a fore-aft motion, meaning they fold up to the rear (Dave correct me if this is wrong). If that is the case then you need to understand what happens when you fold the landing gear up. Look at the attached drawing for this. With the landing gear down the main portion of the weight (the wheel) hangs straight down from the wing, but when you retract the gear that large weight shifts further back on the wing. Therefore the CG of the plane should shift backwards. If you balance the plane with the wheels down then the plane will become tail heavy when you lift the gear up, and since you will be doing most of your flying with the wheels up this probably isn't something you want to do. But instead, if you balance with the wheels up the CG of the plane will shift forward when you drop the gear making the plane nose heavy. A nose heave plane is always better to have. Remember the saying "A nose heavy plane flies poorly, a tail heavy plane flies once!"
So to sum all of that up quick and easy, you want to balance your plane with the landing gear up.
Hope this helps
Ken
