RE: Inverted flight
Well test flight today with the extra lead proved you all correct, just baffled the experts at our site, as the plan flew great before the lead, but obviously this was the problem, may just need to remove a bit, as it now needs about a third down elevator when inverted, and I would like to try to reduce the weight if possible.
Thanks for all you advice.
