RCU Forums - View Single Post - Replacing Tail Boom
Old 08-20-2006 | 05:42 PM
ct420
Default RE: Replacing Tail Boom
The main shaft is probably 'mushroomed' out slightly, most likely where the shear pin hole is.
You can use a file or even some sand paper to smooth down any rough spots on the shaft so it can slide through the bearings...
