RCU Forums - View Single Post - Planes for TD .09
Old 08-20-2006 | 10:30 PM
gcb
Default RE: Planes for TD .09
Sure, the Jr. Flite Streak, Ringmaster Jr., Flying Clown, and Akromaster would work. You may find the Flying Clown and Ringmaster Jr a bit fast. The Jr. Lightnin Streak you mentioned on the other thread should be good also.
As mentioned before, the TD .09 is a powerful engine for the size. The planes above that recommend a .15 were designed around .15's that have about the same power as the TD .09. In some cases the modern .15 is a bit big for these, although they can be flown faster using a higher wing loading.
George
