wing tip help
Several kits have used tri-stock balsa for wing tips. This will provide a nice looking tip that is easy to install. It will result in a tip that looks like what is on the Sig Kadet (though the Kadet tip is built up instead of solid tri-stock) Once glued in place, carve/sand the top surface of the tip to the shape of the airfoil and you are done.
John
