RE: Radio capable of vpp?
You can set up the pitch servo through the flaps channel if you only going to fly normal but it will not do the VPP as you fly. The reason is that you can only set a pitch for the prop before flight or during and set it there. But it will not move at the same time back and forward as you move the throttle. Dose your radio ( Futaba 6exa ) have heli mode?
