RE: Fuel tank issue...
If you guys are having roll trim problems on this style of airframe and the servo's have been ruled out you should take a real close look at the thrust line and whether it is off in the left to right direction. With the sweep angle any side thrust will cause a little yaw then a little roll and you can't just trim it out with the elevons.
