RE: Fuel tank issue...
Hey Moe, I did mine on the cheap with Acrylic enamel. I used a base white with metallic red and gray tones from the local auto parts store. You can get good results, but make sure you use ‘3M Fine line’ masking tape. It’s a blue plastic tape which cost me around $18 Canadian for a 1/8” wide roll. It’s available at high-end auto parts stores.
Chris... Good suggestion, thanks. I’m pretty sure mine is close to bang-on but I’ll have another look at it.
Kelly
