RCU Forums - View Single Post - Composite ARF Impact
Old 08-21-2006 | 05:33 PM
  #740
PeterP
Default RE: Impact
Hi Tom,
I think it was my settings you used to setup your incidences. Great to hear you are happy with it because I am still impressed with my model. Mine is still flying and it has probably done 250+ flights with a DZ160 up front. Mine came out at 4.65 Kg only because my kit was lighter than good building. There is a big variation in weights in kits as I have just bought another which is 150 grams heavier.
I fly the F3A sequences so the model has had quite a workout.
I have spent many hours trying to dial this model in because I am very fussy about having a well trimmed model.
From what you have said can I make the following suggestions which have improved my model enormously.
1. *****Important***** seal your ailerons and elevators (I have a successful method which I have posted elsewhere in this forum). Your snaps will improve 10 fold. I could not get a clean snap consistently until I did this.
2. CG wings off. Set it just behind the rear of the wing tube. Much less work in rolls especially on 45 degree up lines.
3. Aileron differential- 1mm more down than up at low rate. Not sure about high rate.
4. Mix 1-2% down elevator to low throttle.
5. Set thrust as per model. This should be perfect!. Mine climbs straight as - one of its strong traits which presents nice lines between maneuver segments.
Peter.
