RE: modeltech twister
I received by Twister two weeks ago and I am still fitting with the construction defects this model has. My ailerons were warped so bad that I had to make diagonal cuts on them, twist them, and then glue them back together. The instructions, like someone said before, are far from being accurate. I have not change the pull-pull system. It comes with wires but I will change them for kevlar wires. We'll see
GL
