RCU Forums - View Single Post - Matching Elevator Travels
Old 08-21-2006 | 09:25 PM
MikeEast's Avatar
MikeEast
Default RE: Matching Elevator Travels
ORIGINAL: aerobob
jon595, bubbagates - this ATV thing seems to be the solution, and I just basically finished duplicating that "no sub trim, high ATV" that is on the downonthedeck website.... works VERY well.... BUT...
If you're measuring REALLY closely, the travels are NOT identical for two of the three rates. I can get BOTH up and down to be VERY exactly matched, but only on ONE of the rate settings. The others are close, but very slightly off at on or the other end points.
(Head and sheetrock softening now....no hair remaining.... torch at the ready.... )
Bob. I used to have the exact same problem on my planes.
Now, they looked perfect with the naked eye, but with the long stick trick I could get the high rates to match exactly.... but when I set the AFR and dual rate (futaba 9Z) I could not get them to match perfectly. I could get them close, to within 1/8" on an 18" long stick but not exact. I measured and remeasured pushrod lengths and control horn settings with a vernier caliper and they were exact. But the darn throws would not match up. As you said, I could go back and adjust for low rates, but then the high rate would not match. More head banging[:@]. I never really figured that out. I just accepted that 1/8" at 18" om low rates was just EXTREMLY close to perfect and dealt with it. Since I started programming, that became a non issue..
I just dont know and never figured out exactly what the problem was. Was it a servo resolution thing? Was it something to do with using subtrim? The ATV's were the same,,,, I just dont know? IF you figure it out tell me. That is what drove me to programmable servos. I have gotten pretty doggone good at setting up matched deflections mechanically, and what I considered imperfect some may have considered spot on, I dunno.
That slight difference seemed to make no difference on low rates for precision flying, but it made a big difference if I left the offset on the high rate. It would cause lots of problems like dropping a wing in a wall, hard to manage waterfalls, wingrock in harriers. Stuff like that so I always perfected the high rate.
