RE: E-FLIGHT BLADE CP
Chopperdudes,
The problem you are having with the trim is probably due to the fact that you need to adjust the proportional for the tail motor. Use that small flat head and make a slight adjustment, arm the heli and see how it flies. If you still have too much rotation to the left, turn the proportional in small amounts counter clockwise until you get it just right. When you finally have that adjusted to near perfection, kepp in mind that when you are running lower on your battery, your taill will react alot differently. And another thing I would suggest is to heed to Dignlivn's advice and slow down and take baby steps. I have had my heli for about three months and I am still taking it slow. And as most of these guys will attest, taking it slow and learning the basics will save you a bunch of money in the long run. Good luck.
James
