RCU Forums - View Single Post - setting up ailerons with 2 different servos.
Old 01-06-2003 | 10:18 PM
Willy RDRC
Default setting up ailerons with 2 different servos.
I have a DP extra and am putting a JR 8411 servo on the inside (closer to the fusalage) of the aileron and am putting a JR 811 on the outside of the aileron. The 8411 has 155oz. of torque and the speed is .18. The 811 has 55oz of torque and the speed is .18. Both are digital.
I want to know whether I should use a Y harness on the two servos that are on the same surface (aileron) or whether I should make one a slave and the other a master on the radio?
