RCU Forums - View Single Post - Using a RotoZip bit in a Dremel for shaping a stack of ribs?
Old 08-22-2006 | 05:36 AM
lrglnman
Default RE: Using a RotoZip bit in a Dremel for shaping a stack of ribs?
are there any bits with pilot bearings to ride on the templates? you used to get bits that trimmed formica that had a bearing on top some smaller bits had a round portion of the bit that was not shaped to do any cutting and it was intended to ride on a template.
