RCU Forums - View Single Post - setting up ailerons with 2 different servos.
Old 01-06-2003 | 10:43 PM
William Robison
Default setting up ailerons with 2 different servos.
Willy:
There is a very simple solution to your problem: Don't.
Enough difficulties will manifest themselves without your adding troubles of your own making.
Multiple servos on a single surface should always be the same brand and type.
Avoid simple problems - the complex ones will keep you busy enough.
Two servos per aileron or flap,
. Mix 'em up your head you should slap.
Bill.
