Hi All!
Flew reconstructed UCD last night.
Good to be back. Plane flew pretty good considering the heavier weight from all my repairs. It is around 7 lbs. Vertical was not as good with the 82 as before. The plane had some twist in it from repairs and it still flew straight and great. i will put a new fusealage on this winter.
Barry will work on those flat spins. Where are you balanced at?
ForeverHero, Blisster Post pics of the interferance problem if you can. 82 carb is close to side of mount. and I also had to grind off landing gear lug to clear the rear of engine. Mounts are not inverted are they?
Doug
