RCU Forums - View Single Post - Matching Elevator Travels
Old 08-22-2006 | 08:38 AM
MikeEast's Avatar
MikeEast
Default RE: Matching Elevator Travels
ORIGINAL: bodywerks
the hingelines on my Aeroworks 35% 260's elevators are slightly off, placing one elevator half slightly higher than the other. To most, this is probably never even looked at. Then, to top it all off, I misdrilled the control horn by about 1/8" on one elevator half. Both control horns' fulcrum is directly over the hingeline still, but one is 1/8" outboard compared to the other. It doesn't seem like a big deal, but, like Mglavin said, no amount of additional mechanical tinkering or servo programming will ever fix it, not even a Hitec servo programmer. The other thing I noticed (I use the two rods coming to a point behind the rudder trick, too) is that, while I can adjust my ATV's to achieve the exact same throws for a given rate, they still don't move at the exact same rate all the way up to their endpoints[:@]. Besides the obvious geometry problems one can encounter, other factors, such as variences in the servo or servo arms themselves, or a little extra friction in the hinging of one control surface or ball joints campaired to the other, can also reek havok. The best thing to do is to get rich and get sponsored. That way, you can afford a pro-build instead of the chinese stuff, and can have buckets of servos lying around so you can mix and match them to get exactly what you want!
Yep. You are right, it has to be mechanically perfect if you want things to really match up.
Key is to take your time and make absolutely certain that everything is mounted in exactly the right place. If the servos and control horns are mounted right or at least exactly the same on both sides, getting the surfaces to match up is not that hard.
I thought all of the holes were predrilled for the control horns on the QB. Was yours not a QB?
