RCU Forums - View Single Post - Difficulty Tuning an Evolution Engine
Old 08-22-2006 | 09:13 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Difficulty Tuning an Evolution Engine
Try this:
1 Loosen the screws that hold the carb in place
2 Press down on the carb so it is tight against the crankcase
3 while holding this pressure, re-tighten the bolts.
If that doesn't help, do this:
1 Remove the Low End Limiter collar
2 open the throttle 1mm
3 Close the low end needle
4 open the low end needle 1 1/5 (One and One Fifth) turns (this is where it is SUPPOSED to be set at the factory, but a few slipped by with different settings)
5 replace the Low End Limiter Collar.
