RE: Fliton Inspire 60 Acro
got mine in yesterday... great quality, within an hour I had 30% of the airplane assembled, very easy build, probably one of the easiest aircraft to assemble that I have encountered. I measure build quality and accuracy by how well the wings fit onto the fuselage. These slid right onto the carbon tube and the locating dowls lined up perfect with no trimming to get the wing to seat and the gap was perfect around the fuselage cutout and the wing root. The rudder is impressive it would make a salmon jealous. fuel tank needs to be another 100cc bigger (its a 240cc tank) just for a little extra run time. The covering is a great quality but kind of weird... after cutting out the various servo and other surface cutouts and retacking the covering inside the cutouts, I found that the covering would only tack down with a very low temp yet it liked higher temps for re-shrinking. I really like the way the canopy is large to give easy large access to the fuselage bay. If it fly's as good as it looks, this ones a keeper.
