[quote]ORIGINAL: Barry Cazier
ORIGINAL: rtn9105
When you have the rudder in the right corner and the aileron in the left corner and the elvators full down, just hold, hold, hold, and then start sliding the aileron stick slowly to the right. Mine ends up about center. I usually start the flat spin at an idle and then transition to the aileron about center and then pick up the throttle and jockey the rudder and ailerons to keep in flat and start the infamous, envious, rising flat spin.
thanks
Barry
That is what works for me. It spins beautifully. I usually start out inverted. Do you start from the inverted position Barry?
