ORIGINAL: Rs43EVOman
You cant racer .18's can you? From everything i know its only .12's. I like the .12 TZ alot from my on-road racing, which version do i need for my associated GT2? On the Associated site it says i need a Roatary carb and SG typr crankshaft, and that standard engine will fit if I buy [link=http://this]http://www.teamassociated.com/enlarge/2312.htm[/link] clutchnut
Depends on the track but most local small tracks will let you run what ever. Now when you talk big sanctions just depends on the class and the sanction. I know at my local track you can run them and most of the track in middle Georgia let you.
The make the OS .18 CV-R in both short and standard crank shafts with either rotary or slide carburetor. All so they make it with or with out a pull starter if you are going to use a starter box or not.
