RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 08-22-2006 | 06:45 PM
  #5259
raideron's Avatar
raideron
Default RE: U-Can-Do 3d 46?
Hey Blisster.. Not sure if you got your engine/mount fit resloved... depending how far
back the engine is sometimes the carb will hit one of the mount bolts.. I have shaved
some of the head of that bolt in the pass to get all to fit... On "Do" # 2, I did it different,
I used the stock mount and installed up right, and put the S82 inverted on the top of the
mount.. Doing this I raised the carb. a little over 1/2" plus I had more room for the stack
filter...
I did have to trim one of the mount arms to get the carb to fit... All else fit great
even the stack and I believe the filter will work with no problem... You can see pics on
pages 176/4399, 179/4453 & 4463, 191/4755 and 194/4835...
ForeverHero... You can see a little of my throttle setup.....
