RE: Engine identification help!
Walter,
The Weedeater with the intake on the bottom has a use. Pull the crank and cut off the counter weight assembly. You can use the jurnal with the stud as a tool. It works great when triming flywheels and other rotating parts in a lathe or drill press. They will be perfectly centered.
Dave
