RCU Forums - View Single Post - Hangar 9 DVT Voltmeter/Tach Problem
Old 01-07-2003 | 02:01 AM
busdriver-RCU
Default Hangar 9 DVT Voltmeter/Tach Problem
Hey Guys,
I bought a H9 DVT (Digital Voltmeter /Tachometer a few weeks ago, and it came with a battery. It worked fine, but the next time I tried to use it, the LOW BATT came on. I chalked it up to being a bad battery, went and put a brand new Energizer it it, it worked fine, then same ole thing happened......... Next time I went to the field, LOW BATTery again. I blamed myself... maybe laid the thing on its top and kept the button pressed so it stayed on.... I put a new energizer in it, left it on my workbench (turned off of course) came back the next day, and well, I guess you can figure it out from here......LOW BATTery, again, never used, turned off overnight on the bench. Now, it will still give a tach reading with the LOW BATT, but the voltmeter will not read.
Anybody else had this problem?
Keith
Charleston, WV
