ORIGINAL: murry
is that carb on backwards, or mine
The DA 50 carb can be flipped 180, if you do it just be sure NOT to flip the black reed block. That must stay in the same orientation. Instructions from DA were to apply blue Loc-Tite to the bolts then tighten them until the rubber gasket just slightly starts to squeeze out.
