RCU Forums - View Single Post - flutter in aileron and flaps
Old 08-23-2006 | 09:20 AM
  #55
da Rock
Default RE: flutter in aileron and flaps
Since everything is brand new, I would assume everything is still tight.
Sometimes the new stuff is the cause of the problem. Usually the holes in horns are too small for the clevis pins, but sometimes they're too large. I've just spent a couple of minutes going through my parts box matching up the parts for my "everything included ARF" aileron horns/clevis installation. The pieces that came in the box were too tight and I didn't want to use the badly cast nylon clevis anyway. The horns looked good but the holes were too large for the good steel clevis I have. etc etc
BTW, I was just kidding, pulling your chain, about the epoxy/solder. I knew you'd said you were going to do it. But couldn't resist pulling....
