General building Q, how to fill a low spot
I need some advise on how to fill a low spot on my fuse.
I have a b25 fuse that is sheeted but not yet fiberglassed. (I bought the kit partially built) I noticed a low spot/area neart the tail, it is on the side to bottom curve. How should I fill this void?
1. use wood filler? (seems like it would be difficult to get it to stick in such a wide area)
2. epoxy/resin and micro baloons?
3. Glue some balsa and re-sand to shape?
4. Bondo?
5. Fix it after fiberglassing?
Thank you for the help in advance.
Mike
