RCU Forums - View Single Post - TROUBLE SETTING UP ESC
Old 08-23-2006 | 04:17 PM
PhysicsRider
Default RE: TROUBLE SETTING UP ESC
Ok, I have reversed the throttle and here's what happens: When I reconnect the battery to the ESC with the stick at full throttle, the ESC does some crescendos and that's it. It does not go through the setup mode. I can ease back on the stick and only the collective move downward. After disconnecting the battery from the ESC, I place the stick in the low position and reconnect the battery to the ESC. The ESC starts to emit a continuous beep. Nothing else happens.
