RCU Forums - View Single Post - Evolution 58 Lessons Learned
Old 08-23-2006 | 05:16 PM
glofuel
Default RE: Evolution 58 Lessons Learned
I use 3-cell li-po 1500mA the MCU can use upto 13V
The auto choke closes every time the Ign is turned on and will open once the mcu has sensed that the prop has turned more than a couple of times hence the two magnets, which is fine, but I have found it will flood the engine easily if not started within a couple of flicks.
I've also found that some days it will start first flick from cold every time, but flood if hot.
The other day started first flick, flew model then 1/2hr later would not start at all
I will probably plug the servo into a spare RX channel and use my TX.
