RCU Forums - View Single Post - Cermark Pitts Build/Assembly
Old 08-23-2006 | 06:51 PM
V2PLUS10
Default Cermark Pitts Build/Assembly
Based on some posts elsewhere in this forum I ordered a Cermark Pitts S-2 ARF. I'm impressed with the quality of this model but have added a few of my own touches.... I intend to mount a Saito 180 in the nose so the changes so far have been to beef up the nose section and firewall. I have used vibration reducing motor mounts before and really like the result, so some of the additions to the firewall were to allow the use of EVE's from www.apacheaviation.co.uk which require a 1/2" thick firewall. The first few pictures show where I've added 1/32 ply to the inside of the fuselage in the nose section. These areas were only covered/protected by the exterior covering material so to add strength and help eliminate holes caused from working inside the fuse I added the ply sheeting. ....Other pictures show the firewall from the rear and the various stages of installing the EVE's and the motor.....I think that Golden Knight looks pretty good in there!!
Randy
ID:	512099   Click image for larger version
ID:	512100   Click image for larger version
ID:	512101   Click image for larger version
ID:	512102   Click image for larger version
ID:	512103   Click image for larger version
ID:	512104   Click image for larger version
ID:	512105   Click image for larger version
