ORIGINAL: Bax
You'll have to put the throttle->rudder mix before the rudder->aux mix (for dual rudder servos) to get the throttle->rudder mix to link properly to both servos. That works. If you put the throttle->rudder mix on a switch, then you can turn it off when you want.
I finaly had a chance to try out your suggestion. Unfortunatly
it did not work. This is what I did.
mix 1 - elevator to gear for dual elevator servo's
mix 2 - throttle to rudder
mix 3 - rudder to aux2 for dual rudder servo's
link and trim are both on.
mix 4 - inh
mix 5 - inh
mix 6 - rudder to aileron
mix 7 - rudder to elevator
Any other ideas ?
