ORIGINAL: nashtm
Thanks wxman
>>Vertical is all day long
I trust this means *unlimited vertical*
I have had great results with my 91fx's but the noise, revs and non linear throttle responce has gotten to me but I think the 4 stroke will restore my joy !!!
Do you have the the rudder servo in the tail with the Saito ?
I do have the rudder servo in the tail now and ended up with a CG of 5.75" with battery still reachable in the fuselage... ie. not located in the tail. I am probably going to a CG of 6" soon, but 5.75 is still very landable. I harrier land almost everyone now and can touch the rear wheel first about half the time, so the the 5.75" is definitely not the limit on easy landings with this plane.
FYI, I did the rudder servo closer to the tail than the elevator servo and some spacer blocks to keep it from touching the other side of the fuselage. It is covered nicely hidden under the elevators too.
