RCU Forums - View Single Post - temp of engine
Old 08-24-2006 | 09:33 AM
jguitarsandcars
Default RE: temp of engine
No problem Cody...Also check out the thread I just started this morning about problems fixed...I won't get too detailed here, but I was still having problems after sealing although It had run good with a different pipe on a bench test...I took the exhaust pipe apart and found a big chunk of scrap plastic in the chamber between the baffle and the stinger tip, blocking 2/3's of the tip meaning built up back pressure in the engine...
