RCU Forums - View Single Post - problems with my DA50????
Old 08-24-2006 | 10:29 AM
blkbird68
My Feedback: (19)
Default RE: problems with my DA50????
A quick way to check to see if you need to run a line from your static port into the fuse or a box is to simply put a piece of duct tape lightly over the static port on the diaphragm cover. If it makes the problem better, then you need to do it. If it doesn't make a difference then odds are that isn't what is causing your problem.
