RCU Forums - View Single Post - ZDZ problem resolved
Old 08-24-2006 | 12:48 PM
Dangerous Dan's Avatar
Dangerous Dan
Default RE: ZDZ GONE BAD!!!!!
Problem resolved see post 23
Scott you might add;
1. That you mounted the engine, started it and set it rich with 32-1 penzoil aircooled. Took the plane to the field and the ignition was faulty....
2. The engine did not have a manual in the box...
3. It ran like heck it would bog down when you pulled the nose up and speed up when you pointed the nose down.
4. You removed the engine to strengthen the firewall to possibly help this problem and when you reinstalled the carb the carb mounting screws stripped.
5. the carb spacer was warped
6. All modifications and adjustments were made per recomendations you recieved when you called RC Showcase multiple times.
