RCU Forums - View Single Post - Another Tamiya Leopard
Old 08-24-2006 | 12:56 PM
  #44
CapnCrunch43's Avatar
CapnCrunch43
Default RE: Another Tamiya Leopard
At one time, I was ready to just duct tape the whole turret together. [:@]
I ended up using a flashlight to look inside the front with it closed to see where the problem was. Wires passing over the battery, as well as some sticking straight up out of the DMD seemed to be the problem. Stuffed the wires in the pocket on top of the DMD and the battery, as well as bending wires coming out of the DMD. Routed the wires around the battery and that did the trick.
The battery to DMD cables are stuffed down the side as is the limit switch cable.
