Right Thrust
Yes.
Depends on the model, some use an off set firewall, some an offset tail, even different length wings. The firewall (or wedges behind the engine mount, which amount to the same thing) is the most common method
downthrust, which stops an aircraft climbing as power is applied, can also be incorporated in the same way.
Normally these offsets are only a few degrees.
Simon.
