RCU Forums - View Single Post - ZDZ problem resolved
Old 08-24-2006 | 03:19 PM
Mike Dooley/RCS
Default RE: ZDZ GONE BAD!!!!!
The bottom line and the fact is that the engine has ingested the throttle plate screw and destroyed the engine. The carb was removed and the phenolic carb block was reinstalled with improper gaskets and improper sealant. This totally blocked the pulse holes. How can the engine work properly? This most certainly would cause improper fuel delivery and a poor running engine. How can we possibly warrant a carb screw destroying the engine when we do not see this as a cammon failure mode? It is obvious the engine was taken apart and put back together improperly. We stand behind our product line 100% and of course will only do want is fair regarding warranty claims and repairs.
